im thinking of buying another bike. its got a full kitaco motor 124 se topend and i guess kitaco tranny. . how does this motor compare to like the daytona 150??? pulling power, topend and tourqe?? thanks for any help
I've ridden both, I feel strongly that the daytona will have more potential let alone top end stock... with the two ignition wires connected. The 124SE I rode was a tractor... I realize it was on two seperate set-ups and gearing will adjust drive and individual motor set-up will change results.fatcaaat said:What what what?
perfect! 4 is overkill unless your on big outdoor tracks.mutinytattoo said:is 3 gears enough gear to have for racing?
is the 124 gonna lug around since i weigh 180lbs?? do i gotta keep on the gas constantly?burch753 said:perfect! 4 is overkill unless your on big outdoor tracks.
well im looking to buy my uncles crf70 and he has the full kitaco se motor already so. . . i just know ive been told the daytona is gonna run with my 171cc stroker that i have in my 110. so im trying to compare the 124 to what i have now lol. . i guess i need to just ride it lol. . i want to make sure im gonna be ripping with a 124 haha.RiDe said:the 124 is not going lug around at all, its going to be very fast. if I had to choose id go with the daytona only because for the same price you get the entire motor.
wait,, hold the presses,, I believe my V2 headed , 110cc HO engined stock mod bike pulled yours every time, only by a bike length , but it pulled ahead and we then stayed about the same speed.mutinytattoo said:i know this thread is old,,, i wanted to bump it up with my experience of the 2 motors...
i bought a daytona 150,, motor was weak as heel, i put the upgraded cam and high compression piston in it,, made the smallest bit of difference it wasnt even worth the 200 bucks it cost,,motor has 0 bottomend , daytona 150 is a freakin TURD!
now my kitaco 124se i have now,,, this motor is so nasty its rediculous,, me and my buddy drag raced and we are dead even,, the 124se pulls hard and has a ton of topend,, if ported right the head will deliver 2 more HP (from what im told),,,, this 124se will kill alot of motors that are bigger cc than this one,,, i love it and it has power everywhere!! i got a tak 124dohc also, not sure how fast that is but we'll see soon,,,
hahaha my sh*t needed jetting, and my valves needed to be adjusted bad!! one intake valve was tighter than hell, and the ex was way loose,,, im not thinkin you were a bike length tho??Matified said:wait,, hold the presses,, I believe my V2 headed , 110cc HO engined stock mod bike pulled yours every time, only by a bike length , but it pulled ahead and we then stayed about the same speed.
I do agree with ya that the 124se is faster than your Daytona though.
change it minor!magiksc said:Yeah man your motor freakin rips. You str8 hammered down on the throttle last night- I better change my setup ASAP
timing was off so i sent it to castro to set the timing,, hopefully it will rip,,,, ill keep you posted manburch753 said:how did the SE compare to the DOHC?
sounds good,, I am up for that , no problem.mutinytattoo said:hahaha my sh*t needed jetting, and my valves needed to be adjusted bad!! one intake valve was tighter than hell, and the ex was way loose,,, im not thinkin you were a bike length tho??
this motor is sicker than ever now and ill be happy to drag you again![]()
dood said:ummm..... yea.
also my gearing was way offMatified said:sounds good,, I am up for that , no problem.
braaaaaaaaapppp,,braaaap,braaaappppppp thats what he means hahaha jk idk,,,burch753 said:what? I missenterpreted that, lol. How will a DOHC compare to the SE? out of the box?
dood said:Both those engines are similar in out put but the problem is that not everyone has the same state of tune, carb, exhaust, gearing, weight, ignition and so forth and so on.
This has a huge impact on how your engine will run.
