Help identifing this Chinese motor
7.6K views 11 replies 4 participants last post by  jamesfl
You're going to have to pull the engine to do a top end rebuild, there isn't enough room in the frame to slide the head and cylinder off. Once on the bench, then you can determine which cylinder and piston to buy, after you've taken the bore measurement and check the wrist pin size.
