Head Breather
5.5K views 44 replies 23 participants last post by  Waffle
Can everyone explain to me what a head breather does to increase performance? If thats what it does. What does a head breather do? Tell me everything you know, please.
#5 ·
ridedirt said:
thanks. about how much would it cost to get one?
To be honest no more then 3 dollars and a drive up to ace...... I made my own. All you need is to drill a 3/8 hole, or what ever barbed hose addaptor you get, into the top valve cover screw in the barbed hose adaptor and put whatever size tubing the top is. Here is a picture if you dont recoize the name.
#10 ·
I know I must sound like mr. cheap.
You can take a little piece of panty hoe and a ruber band and just wrap it around the panty hoe to make it stay.
It is a very little chance of dirt getting in a tube if its long enough....
Not trying to be the homeless guy just the econmic guy hahahah Youll get the same results with everything I just told you though....
#13 ·
Does anyone else find that the clear hose given with most of these breather kits to be garbage? Mine melted the first ride, and leaked oil spray everywhere. I'm thinking about swapping it out for a breather line from my ktm.
#14 ·
How the heck did you melt it anyways ???
Usually the clear braided hose that comes with the breather covers are better than what you buy at any hardware store ..
I would think if your motor is melting clear braided rubber hose ?? Than you have a serious over heating problem ???
I use the hardware stored clear braided hose and it work great for years !! I replace em when they get really briddle or really discolored from the heat and oil stain .. Doesn't cost much either .. :)
#15 ·
That's the same hose. I don't think it's overheating.. I have an oil cooler, and it's only like 30*F here.. Maybe it's just me..
It's not deformed or anything, but it seems like it's melted to the breather cap. I was just wondering if anyone had experienced this. Who knows though, maybe my jetting is so lean that I'm running hot.
#17 ·
I made one up one time, used the metal threaded valve stem from an old tube, drilled a hole just smaller than the stem diameter, threaded the stem in place with Yamabond on the threads, snugged down the stem nut, and used the braided hose from a hardware store. Worked fine for me.
#19 ·
Hey Tim .., I heard that you have ta worry about screw'n those barb'd fittings too far in , or that valve tappet will hit it and then you bend the valve .. Is this true ?
#24 ·
topr said:
Theoretically speaking...at what point does it become a good idea to have one. Is it a combination of engine mods? Is it as simple as high compression piston = head breather?
Any bore up kit should have one, because when you increase the bore size in a motor you also increase the amount of air movement in the engine cases, because of the larger piston acting like a pump...On a stock motor the breather at the back of the cases is more then enough, on something like a 124cc bore kit, that is not going to be enough to allow the crank case pressure to release through that tiny barbed fitting...If your motors crankcases arent breathing easily, you can be building up pressure in the cases which can blow out gaskets, cause leaks, and also hurt performance slightly...
