Geeco Billet Clutch Basket
3.1K views 10 replies 8 participants last post by  wogtaz ryder
Running a +R/V2/4v and/or a BBK? Then check out the Geeco Billet Clutch Basket. It uses CRF 250 cush drive rubbers to keep the power going strong. Where other clutches slip, the Geeco Billet Basket bites down even harder. This basket use all the major parts from your old basket to make it a perfect fit with your current engine.
ORDER HERE
Installation Notes:
1. Disassemble the original gears from the clutch basket (you will install them onto the new billet basket)
2. Requires machining the holes on your stock drive gear to 27mm
3. You will use your stock clutch plates and discs (or run a 6 Plate TB clutch pack-sold separately), stock inner and outer hub, stock drive gear and stock kicker gear
Fits YX 140/150/160 and Zongshen 140/ Z 155/ 155 HO engines
Includes:
-Billet Basket
-Clutch Rubbers
*COMPLETE UNITS WITH 6 PLATE CLUTCH PACK AVAILABLE CALL TO ORDER
#8 ·
I got one in my daytona DOHC 160 and its a real good thing. After destroying a stock set of rubbers i was looking for something to use and got one right after vegas this year. What a diff it makes. Smooth as. Go the geeco basket.
