First monkey bike, budget build, pure chinesium
14K views 58 replies 9 participants last post by  ioxide
#1 · (Edited)
Sorry its a clone (a jincheng m50 I think, or whats left of one) I've always been a Honda lover but simply do not have the cash to splash on a bike like this at the moment
I saw this bike pop up literally 15 minutes away from me and as it was road registered I couldn't resist and took a bite, it came without an engine which was fine as I had an olddd but low mileage yx140 which I picked up from my friend very very cheap as he had broken the kick start shaft after very few miles.. despite being a cheap fix he would never have split the engine to replace it but it was worth it for me.
The very first thing I did was cut and tig the tank mount 1.5cm forward to close up the gap between the steerer tube but might move it forward again still as there is another tank mount on the frame it will be very close to hitting the tank on full lock however and may leave it be for now already looks far better than it did.
I then knew right away I'd want some wider wheels and road tyres and after some searching I really liked the look of the duro tyres and then by chance a set of 3.5 x 8 aluminium rims with duro 120/70s popped up brand new but unused on ebay and swiftly nabbed them up too, And so glad I did they completely transform the bike in my eyes!! Now i'm just hoping the rear wheel spacer I have ordered is the correct one and they should be all sweet :D Front wheel is now centred after a touch of lathe work and a little shuffle around.
Borrowed my friends camera (I'm useless with it) and got some quick snaps, I think he actually took some photos when I first got the bike I will have to upload them too at some point.
Still not finished here but this is where its at so far, will very likely change a few things yet, still undecided whether to lose the rear rack or keep it I don't think it looks to bad with it but will try it without at some point. I have also removed the fork "extenders" which came with the bike back to their original length but may lower the front an extra 10-20mm yet.
I may end up with a shorter swing arm too as i prefer the stockier look but this swingarm at +8cm is probably far more ideal for the yx140 time will soon tell!
Edit; added some before pics from ebay
#4 ·
Photos are pretty good for being useless with a camera.
Looks like it will be a blast once sorted.
BTW I do like the rack.
Haha thanks! after seeing the pictures my friend takes they look pretty poor though lol, can't wait to get it on the road, mot time soon!
It's a great lookin bike. I definitely like the rack on there. I think the swingarm looks good too...it could be a smidge shorter tho, and would still look good IMO.
Thank you! I'm quite liking it so far, the swingarm came with the bike so I can't complain, I might put the old front black mud guard on the back to fill in the gap under the seat a little, not sure yet might unbalance the front a bit!
Speaking of the front, the forks originally had the fork drop outs facing the back which I could not stand the look of (and probably less stability at speed) so I switched them the other direction and bought a left hand side speedo drive so it wasn't going backwards...
Only thing is the brake caliper is now on the front of the forks, I'm not a fan of this at all but have noticed some old honda cb750s used to run them on the front, Does anyone think this could be an issue? I think they'll be fine but it crosses my mind how much force the caliper mounts can take in that direction and really don't want them to snap off and cause an accident.
If anyone has some advice on that or how to beef up/brace the caliper some how? Maybe I'm worrying to much about it, just a shame as these forks really don't seem bad otherwise!
Cheers
#5 ·
You know you have the fork legs interchanged? The caliper disk combo is supposed to be on the left side with a trailing axle. I am curious what the speedo is telling you because the speedo drive is running backwards :)
ps. Like the low look.
ps2. With a shorter swingarm you could end up with a wheely machine (yx140 has a bit torque)
ps3. Home made exhaust combo?
#7 ·
Thanks! :D
Haha yes that's what I am saying, I have purposefully swapped the fork leg direction as I hate the look of the axle being behind the fork leg, normally on most forks the axle is in front or directly below the leg..
The speedo now works properly as I have bought a left hand side speedo drive to correct the direction and can confirm it works as it should.
My only concern now is the brake caliper mounts are under tension rather than compression when braking and am curious if anyone has had problems with calipers mounted on front like this
Yeah its a home made exhaust job, I hacked up an old rusty pit bit exhaust, tigged back together shorter and painted with hi temp as it was rusted so badly.. I may change in the future but actually think it kind of suits the bike! I have even added a variable exhaust valve for when I need to be stealthy too :D
Clone or not, it’s pretty sweet looking ride you got there.
On the swing arm, can you measure it? I wouldn’t go stock length but maybe something in between stock and where you are currently at. Stock would give you very little room with those tires.
Thank you! :D
I currently have the wheel as far in the drop out as it will go which measures 33cm / 13" from the pivot to the axle, I'm not entirely sure what stock length is but i think around 29-30cm would be just right.
Cheers!
#6 ·
#10 · (Edited)
I did a +1.5” swingarm and I feel it’s just the right look over stock...without looking so long.
Somewhere 30-35mm longer makes the proportions look correct. The fender even fits better.
Thanks, I'll definitely keep my eyes open for something around 300mm in length then, sounds silly to change a swingarm for 30mm but i think it might just make all the difference especially if I lower the forks a little to go with it!
#11 ·
Here is my 84 after I finished the initial street build with stock swingarm and the taller atreet tires. Needed to have the adjuster all the way back.
Here is is with the +1.5” swinger. It is as if Honda designed it more for it. The wheel fits sooo much better within the fender as stated. Didn’t make the bike feel much different on the go and nailed the look I wanted.
#12 ·
Thanks that helps a lot! Definitely looks more proportionate to the bike! what length shocks are those? Mine only has 270mm but where the shocks attach on my swingarm seems a lot further forward than most swingarms I see :confused:
#13 · (Edited)
Stock swingarm is 25,5cm. A +40mm (~1,5") usually drops the wheel right in the center of the rear fender (stock position)
(I never understood why in 40+ years of j1, jz and FI the rear wheel was so far forward in the fender. )
ps. attached some stance fragments out of the 2017 daytona catalog.
#16 · (Edited)
Those are very helpful thanks a lot!
Those shocks are off an XR75 or XR80 and are roughly 305mm. This setup is probably at the limit of height and if you are lowering the front end a bit, the shorter shocks might be just right.
Yeah I guess you're right I'll have to mock up some shock lengths with a piece of wood to see which looks best
Cheers!
Edit; are most of the clone frames extended a bit compared to stock? does anyone know where to measure from to compare the frame lengths?
#15 ·
#17 ·
I’d imagine if they were extended, its would all be just behind the neck tube. So, there is typically more space between the bars and the front of tank.
#18 ·
That makes sense, It looked as though there was quite a gap between tank and headstock..
It also seemed like quite a gap between cylinder head and front wheel compared to other bikes, which makes me wonder if the slightly longer swingarm will actually suit the bike better than a shorter one, funny how a few different measurements completely change the look of these bikes!
#19 ·
The longer neck is because most of the chinese monkeys are also available in a 125ccm version. And a 125ccm engine builds longer as the standard 50, cilinder deck height 50=63mm, 125=78mm.
ps. That second(forward) mountpoint is for a monkey tank, the rear one is for a gorilla tank.
#21 ·
Does anyone know how difficult it would be to retrofit 88-99 z50r plastic/tank to this bike I have? I really love the look of them and don't have much problem cutting and adding some mounts here and there as long as the frame isn't radically different, I'm only toying with the idea in my head at the moment!!
#22 · (Edited)
That’s a lot of work. Certainly can be done...in fact I remember reading a thread of someone (maybe not on here) retro fitting an 88-99 setup to a frame. Thing is, it’s not just the tank. It’s the tank, rear fender/plastics, and the seat. Also, you can not move the tank around without moving the seat and plastics with. They all fit together. Oh, and the tank doesn’t look right on it’s own as it has a locating portion for the front portion of the seat.
If you really like the look, it would a million times easier to find a roller of one.
That said, have you looked into a Honda QR50/Minimoto seat setup on a monkey/Gorilla?? Now that’s a sweet, unique look.
#23 ·
T
Yeah I guess it would be quite a hassle, I do really like those qr seats with the gorilla tank but they seem pretty pricey! :(
#24 ·
They are! There are two different mounts you can get...but both are expensive. Then you have to get a seat...which only comes in red. They look super rad though, just wonder if they are comfortable to sit on or do you have to basically hold yourself on the seat with such and angle
#25 · (Edited)
They do look rad for sure! and yeah they do look like they lean forward a bit! Its probably not too bad if you have rear sets......
Rear sets, another thing id love to try out on this bike but again pretty costly!
I might have to keep my eye out for a set off a different bike, might be difficult to mod them to fit though
#28 ·
The best seat still is the gorilla seat itself.
Backstepkits also introduce their own can of worms. Kickstarters which will not get past the step is just one of them. Ground contact in corners, seat position with handlebars.
ps. as owner of a baja(avatar), say plastic r with street gear, that seat is too low for me for long rides. Sharp knee angle and thin polster. I once did 120km(75mls) in three stages, I was very glad to get of at the end.
#29 ·
I can't imagine any of these bikes being super comfy. I mean, they are tiny bikes, better suited for a childs frame:) I'm not sure the furthest I have ridden mine but I'd imagine 75 miles would yield a similar result...but now I HAVE to try it. Haha!
I think that most of these builds are form over function. Somethings just look too damn cool NOT to want to install. Guess it depends what you want to do with it in the end. Is it a show piece or will you be putting thousands of miles on it?
The stock Monkey seat, as well as the stock Gorilla seat, both looks extremely comfy BUT (to me at least) both do nothing for the looks of these bikes. The seat you currently have is a really good looking option for a Gorilla tank in my opinion. Not as tall and chunky as the Honda Gorilla seat. I'd be happy with that!
#30 · (Edited)
Maybe I wont delve into the rear sets and different seats then.. kinda glad though this setup is pretty comfy as it is to be fair!
Took it for a quick spin earlier and I don't know how much these wheels and tyres will effect the speedo, they're only a little smaller than the original wheels/tyres but the speedo goes off the clock to around 80 mph lol... maybe thats normal for 17-26t gearing and a 140 but I thought it would struggle to do 70mph
Got the rear wheel spacer in, needed a little file work to fit, not sure what hub this was made for exactly but does the job now!
Might get a little chain slap but nothing I'm not used too.. glad they're 3.5" though 3.75 or more probably would have been a struggle, with these tyres at least!
Also made a little bracket on the bar clamp for rpm/hour counter and a switch for variable rev limiter...
Might have to even make a little lightbar for this bike haha 5x xhp70.2 leds should do :D
#31 ·
That spacer was for the front where is nothing on the one side. The rear has the extra bit for the sprocket.
If you want to get nerdy, you can measure both wheels setups and figure out how different they really are. Just need to find the circumference of both inflated setups.
I’ve done 65mph on my so far and let me tell you, feels like I’m breaking a land speed record from the saddle. Haha
#32 · (Edited)
ohh, on the website it didn't actually say front or rear so I had just presumed lol, should still be good I think!
Yeah I will have to measure and calculate it just incase.. funnily it actually felt pretty stable, considering I thought I'd need a stabiliser/damper but now I might not bother, I guess the extended frame/swing arm and forks the right way round helps a great deal at speed
#33 ·
I’d think you’d be fine with that spacer.
Just because it’s easy, you could just use your phone with a gps speedo app open on a nice clear stretch of road (no trees or tall buildings) to get an idea of speed.
#35 ·
Little update, Got the variable exhaust valve hooked up to the friction lever, works pretty well for a mock up / experiment :D
Also mounted the oil cooler on the forks as it fit quite nicely, only a cheap billet cooler atm, and whilst I was digging in the shed I found some old fork stanchion guards which are a bit big but thought I'd make use of them lol.
On another note I'm wondering if anyone can give any advice on a carb for a yx140, I was looking at the oko 26mm I currently have a molkt 26, does anyone know if this is a worthy upgrade or not?
Cheers.
#37 · (Edited)
update
So I have this old mikuni I have no idea what its off but pretty sure its genuine, its 28mm.. it is missing the slide but the one from my molkt seems to fit, other than that its all there but the fuel float valve has no rubber, not sure if this is normal or not..
I don't know if this carb is worth tinkering with or not but I have my molkt working sweet now it just needed a slight tweak of the float height!
Also made an aluminium rear fender/ mud guard I think I've seen something similar on some z50r's - should help keep the water out of the battery panel.
Also dug up some random air cone and it was the perfect fit, epoxied some k&n filter mesh in there, not too bad! :D
And another monkey bikes appeared, my friend just picked one up himself a skyteam 125 so now I have someone to ride with! I think a few of my mates are gunna want their own now haha! :p
Edit; added some before pics of the bike from ebay on the first post
#38 · (Edited)
update - yx140 / yx149
Some other small bits changed..
Picked up a cheap new brake disc, still the same size but looks a little nicer :)
Got the variable exhaust valve sorted, before I couldn't get good friction on the lever to hold the butterfly valve closed but a small o ring fixed it and works perfectly now - super quiet or super loud !
Also dismantled the shocks to check what damping they had left, surprisingly they weren't too bad considering the state of the last bike they came off! I left them wound out just 5mm more at 275mm and I think the bike is really sitting sweet now!
Lastly I'm wondering if anyone here knows much about the yx149 engine, As far as I can tell it shares the same cylinder head, barrel and 56mm piston as the yx140 but has a different 60mm crank shaft does anyone know if it would be possible to run this crank on the yx140?
I have no idea if it would even fit they "look" similar, measurements unknown however but wouldn't running this crank reduce the compression a fair bit? or am I missing something?
If thats true I presume it would also increase torque and lower rpm which i thought might be more suitable for the road?
If anyone has any info on that would be great!
Cheers
#39 ·
Drive the nuts of the 140 and then switch to a complete 149/150-5 or whatever yx calls that hondalike head engine. Advantage bottom end 149, a regular oil filter and no more stripped screw heads on the oil spinner.
#40 ·
Haha I kept telling my self to do this but when these engines break they're just so cheap to repair I can't resist - unless something completely grenades and its just not worth it that is! :D
