C chalkinblue · Registered Joined Aug 8, 2009 · 31 Posts Discussion starter · #1 · Aug 12, 2009 Only show this user What is the easiest way to get the lights to work when you have a Lifan Engine in a 1974 z50?
big pete · Registered Joined Apr 12, 2008 · 1,150 Posts #2 · Aug 12, 2009 Only show this user 12v bulbs, rectifier, flasher relay, CDI, ignition coil, and battery
tmas · Administrator Joined Apr 9, 2005 · 13,109 Posts #3 · Aug 12, 2009 Only show this user 12 volt wiring harness might make things easier. tmas
L leel · Registered Joined Apr 8, 2009 · 14 Posts #4 · Aug 12, 2009 Only show this user Or, just put a 6 volt regulator from DRATV) in between your 12 volt engine output and your stock wiring, and keep all of your stock lights and other wiring... Lorrin
z50 chopper · Registered Joined Jun 29, 2009 · 1,458 Posts #5 · Aug 14, 2009 Only show this user sorry for the slight thread jack What can be done to convert a 6v engine to 12v?
