Cartridge Emulator Review
8.6K views 8 replies 7 participants last post by  iSsUEs
Rather than keep posting in another thread about the installation of the Race Tech emulators I figured I'd start a new thread for my review. Hopefully this will help some of the people debating buying these.
Installation: The install wasn't too bad, if you can change fork springs you should be able to install the emulators. The only additional steps are to drop out the damping rods, drill the compression holes out and reinstall the rods. I went with the BBR damping rods which I installed at the same time. Be careful with the allen head bolt on the bottom of the forks, I almost stripped one completely and did have to wait a few days for a new one to come in. There are also little copper washers that go under this bolt that you should probably replace when you take the rods out. After you reinstall the drilled rods you just drop the emulator in, put the fork spring on top and close up the forks like normal.
Setup: The best thing about the emulators is that they give you all kinds of adjustability for the stock forks. I'm 165# and I went with 15 wt oil, 3 turns of preload on the emulators, one stiff and one stock spring. I'm running a stock shock with stiff spring on the rear. The engine is still bone stock so I'm not out there jumping anything huge yet.
Impression: These forks are WAY better than stock now. I haven't ridden any other setups to compare but I'm going to be happy with these forks for quite a while. I was at the track yesterday and only bottomed once and that was when I cased jump. I may make them a little more plush by adjusting the preload on the emulators, but not by much and they are more than adequate to ride as they are now. For anyone considering these I definitely recommend them. With springs, extended damping rods and the emulators I spent less than I would have for E-6 forks, have better internals, and I guarantee better performance when my forks are properly adjusted. I'm sure these won't really compare to the aftermarket inverted kits but for ~1/5 of the price or less they are a really good deal. Pair this with a works shock (my next purchase) and you have a good, relatively cheap setup.
#4 ·
you can weld your stock damping rod holes to save more cash it tells you how in the instructions but you wont gain that 1 inch as compared to with the aftermarket ones i have this an a fox float out back an couldnt be happier they are great with the stock swingarms
#5 ·
I drilled the holes to 1/4" and added 2 extra on each rod like the directions recommended. The purpose of drilling the holes is to allow free flow through the rod so you could go bigger on the holes but then you might affect the integrity of the rod. Just follow the directions and there will be (4) 1/4" holes on each rod.
The welding that is talked about in the directions is for the rebound holes, not the compression holes that you enlarge. That step is optional and I didn't do it. And yes, you can install the emulators with stock rods, you just still have to enlarge the compression holes. I wanted the extra length from the BBR rods though. One thing though is once you drill the rods you have to run the emulators, the forks won't work without them.
#6 ·
How much is an additional 'adjustment'?
I have bbr springs, bbr rods, emulators, and m 155lbs. and they are too soft for me.
I want to increase the compression, so do I need to TURN THEM CLOCKWISE?
How much is a noticeable adjustment?
#7 ·
To increase the compression damping you turn them clockwise and then tighten down the nut on the back. I haven't adjusted them since I installed them so I can't say how much difference each adjustment makes. The instructions said to go half a turn at a time, I went with 3 turns or 1 turn over stock.
#8 ·
I talked to Duane (Brown) at BBR a while ago about the emulators. He told me that they tried them in their bikes before, and with the damping rods. He said that they couldn't tell the difference with or without them.
I have a set of stock forks on my play bike with rods and one stiff spring. They are better than stock, but they chatter on small chop like braking bumps. KX60 forks were almost the same. The best reults I've had are KX65 forks with minibike springs. Plush, great feel, great brakes.
I was thinking about trying the E6 front once BBR gets a disk brake setup for it, but I'm leaning towards a '00 or '01 (shorter) KX65 front end on my playbike with the stock swinger and Works shock. I'd have it up in the tree about an inch to get it to sit right though. ----L*64
