anyone else have a cam chain problem where it falls off on the flywheel part. I've worked on the motor a bit and when i put it all back together and take it for a spin the chain will come off.
Joeybags919 said:its not anything to do with the spring or tension, it is in the cases. I have had his bike apart a few times anf I don't get it the chain always falls off of the crank sprocket, and ussaly you have to pull the side cover to get it back on. no one else has had this happen?
Joeybags919 said:its weird because once the chain is on there is does not come off, it is just when you are setting the timming, you have to hold the chain tight when putting the head back on because if you let it lose then it falls off. I think that it is somthing bad from yamaha, because it did it the first time I had it apart, probably a bad gear or something.
kmkBlazin said:yea now it falls off when i ride. Kinda sucks.
