What he said!
This is my plan when I blow up my stock motor along with a 4 speed trans with an HD clutch and if you want speed now then the 88 will do it but the stroker 108 is WAY better.
No TB head on my bike just stock and still waiting on my cam. I have TB 20mm carb and the rev box is from TB also, they call it the "Red Box" it basically advances the spark timing slightly and eliminates the rev limiter.
As far as can I ride it without tinkering . . . . . I have put 800 miles on her in 2 months and the only issue aside from constantly needing to fill my tiny tank way too often is I snapped one of the exhaust studs off and had to have a machinist remove it for me.Best $40 I ever spent.
Bottom line is the 91-94 ct70's are a CRF70 motor with a lighting coil, neutral switch and slightly different gears in the trans.
That said, do a race cam and rev box with the plug out of the pipe and it will look stock and go good or you could add the carb and pipe like I did too.
The Chinese motor swap is easy since these bikes are 12v and motors are $300-700 which make them cheaper than building up the stock motor but the honda will run better and stronger in the long run.
