will it work good in my gpx and will it be reaible??
rkfinch23 said:you can NOT bore the gpx cylinder out to 56mm. the lifan is the cylinder you can take to 56mm
lilchris said:so will it work or should i just get a 56mm or keep my 54mm
fatcaaat said:The piston you call for from dratv is incompatible with the gpx head anyway...
