The case splitting is really easy and the Trail Bikes drum is what I run, as it is steel. None of your gear ratios change, but you get another whole gear.... this does allow for more gearing options when motard racing. the close ratio 4 speed trans is really just for dirt use.... The stock ratios are great for motard use. When you put your 4th gear drum in, you will want to use a "bump-start" device or do your own work to eliminate the neutral safety switch that picks up from the end of the shift drum on the left side of the bike. The aluminum drums don't always allow for a good contact, so the result is total loss of spark.
Even if I only rode on tracks that allowed me to get into 3rd, I would still stick 4th gear in it, since the jacking around when not racing is priceless...
