2003 Klx110 build questions
978 views 7 replies 4 participants last post by  5dollamilkshake
Ive got a 2003 klx110 and i have a few questions about what parts i should buy. Right now the only mods ive done are
-tb pod filter/ air box mod( i switch back and forth depending on weather)
-85 main, 40 pilot
-tb handle bars
Next on my list to buy is a cradle and suspension. If i get kx60 forks and a +2 swingarm then what length shock should i buy? Also what springs do i need to buy for the kx60 forks? Im 160lbs and i plan to jump alot once the mods are done just to let everyone know. Ive searched alot about this and theres so many different setups out there that i get confused on other threads. Appreciate any advice!
#2 ·
Not sure on the shock length with a +2 swinger, maybe like an inch longer? Hopefully someone else cues in on that.
Definitely grab the cradle from Vince at Tbolt, very simple install and you notice a difference in the stiffness of the bike I feel.
Kx60 front end... I have a complete one here with the wheel,brakes and trees if your interested. Never set it up though. Some people say put 20wt oil in it with the HD forks for a klx, others pump the shit outta the air valves, another guy told me to put the heavier oil in and cut 1 1/2" PVC spacers to put on top of the springs and slam the fork caps back down.
