Ive been searching and reading and searching for a good way to convert the front drum of my 2010 KLX100L to a disc brake. Everything I've read was either unclear or clearly written for the KLX100 (not the new L model). Most of the posts I have read are more focused on improving the suspension, and with the suspension upgrade comes the added benefit of disc brakes. Since I have the L model and don't jump it or do anything too rough with it except play around in the trails behind my house with my kids, I really don't feel the need for an upgraded suspension, although in my case the disc brake upgrade may have the added benefit of an improved suspension. So far, all I have learned is to stay away from mountain bike brakes, and that a new hub, & forks will be required. I wish there was a wheel/fork/brake setup that could fit my stock triple clamps, but it doesn't look like that's gonna happen.
I don't want to spend a ton of money, so BBR stuff, zoke forks, etc are out. I'd like to find some stock pull-off stuff on eBay, Craigslist, another PM member, etc. I was considering going with used a KTM65 fork, front wheel, and brake assy. Everything I have read so far is either unclear, or clearly talking about the regular 110 (not "L"), so here are my questions:
Will the KTM forks be a downgrade, the same, or an upgrade from the "L" forks?
Will I be better off using KX60 forks? KX65? Or something else (CRF150 maybe)?
Are any of these fork setups taller or shorter than the stock "L" setup I have now?
Are there any fork & wheel assemblies (with disc brakes, of course) that will fit my stock triple clamps?
If not, is there a triple clamp available that fits the forks AND has a same legnth & diameter steering stem to fit my frame?
If not, will I need a set of custom sized bearings to make the triple clamp work?
If not, can I press the stem out of my KLX "L" triple clamp & install it on the new triple clamp?
Is there a better way to achieve my disc brake goal?
