Hi everyone!! I need a little help on the wiring of my ZB. Actually it is more a theoretical question, since i haven't run the engine yet, regarding the tail light and the speedo light. Following the wiring diagram attached, i found in this forum, it is shown that the speedo light connects to the yellow wire coming from the stator, that passes through the rectifier, and the tail light connects to the black wire, that is connected to the turn signal relay, which connects to a brown wire at the tail light. My question is, if they are both connected in this way, won't they be always on?? Since none of them passes through the hi-low switch, how do they are supposed to be on, only when you turn on the front lights?? Hope someone can help me!!! I can provide
photos with the motorbike wires if needed.
