1 - 3 of 3 Posts
I know I've read this here in the forum before, but I can't find it....
How do you replace the stock throttle cable on an early Z50A? The carb side is dead simple, I need help at the throttle end.
Rob.
Discussion Starter · #3 ·
The answer is:
Remove kill switch (If on right handle bar)
Remove rubber throttle grip
Remove grip set screw (small, underside of bar, close to brake perch)
Remove throttle grip pipe
Remove throttle wire hinge
Remove throttle cable holder (base of throttle cable threads into this)
Remove throttle cable grommet from bar
Pull cable through handle bar
Installation is reverse.
After sorting through this, it appears my new cable has about 1/2" too much jacket (not exposing enough cable). The fun never ends!
1 - 3 of 3 Posts
