1 - 4 of 4 Posts
Finally getting around to putting this bike back together…
I have an issue with the choke. When I assemble the choke and insert the lever through, there is a ton of play between the choke valve and choke link, and the link falls out and disconnects from the valve. I do not see any other parts on the parts diagram, and don’t recall removing any parts.
Does the link need to be bent a bit more in order to retain the choke valve?
Hand Camera lens Finger Engineering Thumb
What am I missing?
I think you just need to push the lever further in...do you have all of the washers and spacers etc for the threaded end?
Discussion Starter · #3 ·
Thanks kirrbby!! Fixed in 2 seconds. It would be something obvious like that :rolleyes:
And thanks again for the choke valve … that’s your valve I’m installing.
1 - 4 of 4 Posts
