1 - 20 of 20 Posts
Hello members
Question , I'm going to do a a 108 stroker kit on my 69 Z50 , I already have a 20 mm carb
On it now with a 88 BBK with race head , question is will I be able to get a 24 mm under there
When I do the stroker set up ? Thanks
use the 20mm carb. A 24mm carb will forever be problematic off-throttle unless the carb is an MJN24. The best running 108 I've every done had a mikuni VM20 on top .
Discussion Starter #6
Glad to hear that, everyone on here was saying to use either a 24 or 26 to get the most out
Of a 108 , I was going to see if a 22 would fit , glad to hear a 20 would be fine . Thanks
I just put a VM26 on my 117 stroker and I love the new found power. I had a 24 and it was lacking just a little bit. Now she's a breather!
Regardless, I would spend the time and make sure you get a genuine Mikuni. my 24mm was a knock off that I ran for 14 years and now that I have a proper running rig, it's make the enjoyment that much more fun. I didn't know it could run so good. just 2 cents. hope ya find the sweet spot;
Not sure on tank clearance with a 69 but my 86 z50 with a vm22 clone on a Lifan 125 is like a mm from touching each other (carb to tank petcock). I had to go with a 90 degree petcock for it to work so an even bigger carb on my setup wouldn't fit. Also yes a genuine vm20 or 22 would rip on a 108.
I inserted a 1" x 1" piece of wood under the rear tank mount on my '69 hardtail to use the TB Parts 20mm carb and manifold. I also used a TB Parts petcock with the 90° outlet so it would (just barely) clear the UNI filter. If you were intending to use the TB Parts 24mm carb it will not fit, it is taller and a little wider than the 20mm carb in the pic HERE. You can see that there is no heatstop, using it would have pushed the filter up into the petcock.
Discussion Starter #12
I didn't think it would fit , what I thought was a 20mm carb on it now turns out to be a 19 mm, its pretty tight but it fits nicely , I see from your picture that a ShengWay 20mm will really be a snug fit , I kinda like the way the 19mm fits, I'm thinking about doing a 108 stroker, what would your opinion be if I stuck with the 19mm on a stroker ? Might not be worth doing if I can't fit a proper carburetor . Thanks
I swapped in a different engine/carb setup than the one above, it is a "small block stroker" engine with a 48mm bore and TB Parts 51mm stroker crank, and I tried out a Molkt PZ22 carb for fitment. I ordered it from Amazon seller XLJOY for around $25 or so. It takes genuine Keihin jets and seems to work real well with the TB Parts manifold. You can see how it sits in this pic
To answer your question, I've run the Shengway 20mm carb on 108 stroker engines with no problems, you'll have plenty of low-end torque. I would think you'll have similar results using the 19mm carb you have.
I can second that. Running TBs 108 strocker with their 20mm carb. Jetted correctly and it runs great! I’m geared for top end and have reached 65mph (on a hill) on 8” wheels and trust me, that’s plenty fast. Cruises at 52mph on flats. Geared lower and it could be a wheelie machine for sure.
Discussion Starter #16
Great , I ordered one couple days ago hoping it's a shorter profile to fit under the tank, from the pictures i seen it looks like it's shorter and from your pictures it looks like it might work out for me ( did you raise your tank with the PZ22 ? ) and also what's a good starting point for a main jet on a 20 and 22. Thanks
On a 20, and at 100ft above sea level, here what I did:
Carb. 90-92 main, 38 pilot. 3rd (mid) needle position.
1-1/2 to 1-3/4 OUT. Adjust 1/4 IN till perfect.
My 20mm settings are similar to 66Cooper's- 90-92 main , 38-40 pilot, 4th needle position from the top, and 1.5 to 1.75 turns OUT. For the PZ22 that came with a 75 main and 35 pilot, I went up to an 82 main and a 40 pilot and the 4th position for the needle clip.
The same air screw settings and adjustments, as well, with a 1/4-turn IN at a time to fine tune it
Discussion Starter #19
Did you have to raise your tank with the PZ22 ? Thanks
I leave the piece of wood in place on the bike, so, yes, the rear of the tank is raised 1 inch.
1 - 20 of 20 Posts
