ballzee99 said:
I have xr75 shocks and the heavy duty springs from fast50s on my 74 z50. The springs up front made a vast improvement and were ~$50, I cant remember.
ballzee99 said:I am looking to make some upgrades to my stock suspension and have seen just about everything installed on the front end of a Z. I am looking for something bolt on if possible. I was reading that the xr75 and xr70 forks are a good choice for the Z. Do the xr75/70 top clamps bolt on as well? Is there any fitting problems with the tire size difference? I was hoping to find a install that someone posted to see what I am getting myself into before I start. Any info or suggestions on forks would be appreciated.
ballzee99 said:What did you use for top/bottom clamps? Did you have to do heavy modifications? Can you post a pic of your setup. Thanks for the reply
mexicanyella said:What year Z are you working on? I've got a '74 softtail parts bike with a two-piece top clamp on it. I'm not sure if this is standard for that year of it's off some other year, but the point is some years you could unbolt the fold-down handlebar arrangement from the top triple clamp/plate, and replace it with bar clamps from a small Honda that used standard bars. I think you could use SL70, XR 75/80, etc. for this. So, if you're working with an older bike with the one-piece cast aluminum top clamp, maybe you could find a top plate off a later year, for cheap.
Or just shell out for the fast 50s setup, which is probably stronger and certainly blingier.
cdoublejj said:i wanna fix up the supsenion in my 74 z50 too was looking at these springs but also saw the new fork legs and bushings.
Fast50s.com "The Original xr50 Specialist" - Performance Parts Front Fork Springs
will the springs improve stability and stiffin up the front withstock legs?
Fast50s.com "The Original xr50 Specialist" - Performance Parts z50 Stock Replacement lower fork legs
says they are longer and lower really? if so by how much i don't wanna change the stance but just get something sturdier.
Fast50s.com "The Original xr50 Specialist" - Performance Parts Fork Leg Bushings - Fast50s Fork Legs
and i guess these are need for the fast 50 legs.
Fast50s.com "The Original xr50 Specialist" - Performance Parts Fork Leg Bushings - Stock Legs
but are these worth any thing?
personally i doubt i could afford any more than the springs and stronger bushings.
oh what about stiffer rear shocks?
