The stands are awesome, you can fit drain pans under them, you can flip the engine vertical or horizontal. Albeit a bit expensive, if you plan on working on your engine(s) a decent amount over the years its worth the initial investment. I have had the same ones for 4 years also, so they hold up as well and will fit any engine with the Honda motor mount, which includes YX engines.
