1 - 4 of 4 Posts
So I just bought a 184 kit with the v2 roller head because the stock head took a crap on the 160cc cylinder but anyways it’s in a pitsterpro x4 and I can’t get the exhaust to line up. I’ve drilled the holes bigger on the pipe still dosent fit. Has anyone had this problem or can help me before I cut and weld this one?
V2 head is a klx port and the port angles are different from the crf head most yx160 would come with unless you have a tx model. As for an exhaust that might fit you could look into buying a klx big bore pipe and use the first bit of the pipe to weld up an exhaust.
1 - 4 of 4 Posts
