1 - 5 of 5 Posts
Getting this thing sorted and jetted right and its running pretty good. Got shock, fork springs, and bigger handlebars.
Looking at next mods I'm curious what you guys would do? I'm thinking either a manual clutch kit OR a inner rotor kit?
Would like more oomph off the corners.
Or maybe something else? Smaller front sprocket maybe? I'm an average sized adult if that matters.
Thoughts??
Discussion Starter #4
If you don't have an aftermarket exhaust, that should be next. Also hope you did a cam as well.
stock exhaust with baffle removed, uni filter, 20mm carb from TBparts. does aftermarket exhaust do much? got the 88cc kit from a mod here, so not sure on cam. It's the takagawa kit though, so maybe came with a better cam?
1 - 5 of 5 Posts
