has anyone done this, if so how did it work out, any gain?
AHRMA361 said:You will need a different intake (that is taller and one that has the correct carb stud spacing), throttle cable, and air filter. Unless you also open up the exhaust, maybe change cam, head, valve size as well, you will probably make it run slightly worse than stock. Just my .02
