1 - 13 of 13 Posts
Discussion Starter #4
Yes im getting fuel, and i know its set right because it was tuned to the motor with the old head. I just replaced it because the exhaust studs broke off in he head.
Im gonna try cleaning the carb again
get it running ? if you have good spark and good fuel flow then it's gotta be valves too tight or timing is off
Discussion Starter #6
havent messed with it yet but yea its go good spark good fuel flow and valves arnt too tight. So ill go out in a little bit and do the timing
fiddy4ever said:
The timing is dead on (i think its a sikk mx 120cc motor with 3 bolt cam so im not sure exactly how the timing works)
u should b sure of wut motor/head u have. double check that u have the right head.... and that u know how to set the timing.... and check the valves for that matter.
Discussion Starter #10
its the same head as the oem head. I bought a take off from another member, and i checked the valves and all before install.
And yea i was thinking it is proubly 180 off or something i will mess with it later
Discussion Starter #13
DEMONDAVE said:
remember the old saying "valves & timing set them once check them twice".
ive checked and re set them quite a few times lol But im just beginning to thank that its the timing for sure
1 - 13 of 13 Posts
