Wierd problem with tb clutch kit
509 Views 4 Replies 4 Participants Last post by  CrazyJohnny
Hey guys, I have been have some wierd problems with my trail bikes clutch lately. Here is what is going on. Sometimes when I kick through a cycle, the engine feels like it has no compression. It feels like when I try to kick it over with the clutch pulled in. But other times I kick it through it is normal and starts fines. Anyone have any idea of what is going on?
1 - 5 of 5 Posts
Yeah the clutch is being engaged when it shouldn't be so yeah it most likely needs to be adjusted
Chances are you have too little or no free play at the lever causing the clutch to be held slightly disengaged. This will wear out the throwout bearing and the clutch pushrod pretty quickly if you don't fix it.
thanks for the help guys. Ill loosen up the adjustment and see what she does!
1 - 5 of 5 Posts
