1 - 7 of 7 Posts
ok, bought a beat up '82 atc 70. no spark in all of the run switch positions. when i pull it over and rock the switch it will spark. i tried find a spot between on/off where it woudl work, no go. tried jumping the on-off circuit, no go. wtf?
dont jump out the kill switch circuit all your doing is grounding the primary circuit you will never have spark. just unplug kill switch wires and leave them apart and check for spark if you still have no spark put in a new set of points or clean and adjust yours. but i have seen the points where they ride on the crank wore out and they wont open hope this helps
Louk
Discussion Starter #7
so i had spark when i left the shop last night, today when i get there it has nothing. condenser and pickup tomorrow then ... new motor with cdi if that doesnt do it.
1 - 7 of 7 Posts
