1 - 9 of 9 Posts
I have an 04 CRF 50. I have put a uni airfilter, rev box, DPM valve cap breather and fast 50s pipe on it. Has helped top end a lot but bottom end sucks. Whats up? I was out riding yesterday and my buddies 50 that is bone stock can get me off the line everytime. Where did I go wrong. Or what do I need to do to fix it without doing a big bore kit?
well first off make sure that you didnt buy the fast50s "BIG BORE" version pipe...doing so will clarify your not an idiot :D
next...many peoples carb has to be tuned after UniFilter/PIpe Installed...
and to help you out with that....
http://www.ministothemax.com/hop_ups_carb_tuning.htm
-binH
yea when i put a differnt cdi on mine its a kitaco it had less bottom end i think they change it to all top just try the stock cdi and see whut happens
The Kitaco CDI will show no gain or loss on a stock motor. It's the exhaust pipe, and the air filter.
A better exhaust will flow more freely, and will cause you to lose more low-end torque unless you have the motor set up properly to support the pipe.
Discussion Starter · #8 ·
Its not a big bore pipe. It is for the 50cc motor not 88cc. This is not my first 50. I had and 03 with the same pipe and didnt have this problem. But it didnt have the rev box or airfilter.
check your valve clearence!!!
Make sure your filter is throughly oiled properly
If you plan on keeping it stock for a little while, you can do a simple port job and it will increase your bottom and mid.
my 2 cents
Later
1 - 9 of 9 Posts
