1 - 2 of 2 Posts
I want to get a new chain for m pit bikes. I know my ssr sr 125 has a 420 size chain. Im unsure how many links though that would help.
I also have a 160 tr that I want to get a chain for.
What size does it take and how many links?
Thanks
Vendor
You just need to cut it down
[h=1]Renthal Gold Chain 420 x 130 Length
Part No: W-25-2130
[/h]
The R1 Works Chain has the following features:
  • Shot-peened alloy steel side plates for high tensile strength and maximum impact load resistance
  • Chamfered inner links to reduce the chance of chain derailment
  • Extended bushings to reduce friction between outer and inner link plates, maximising power output
  • Chromised bearing pins for excellent resistance to wear
  • Gold colour side plates help prevent corrosion
  • Most perfectly matched chain for Renthal chainwheels allowing maximum power at the rear wheel.This also extends the life of both the chain and chainwheels420 x 130 links
    [h=1]Chain Breaker tool
    Part No: 1773
    [/h]
    Chain Break tool.
    This is a must for custom cutting and of your chains.
    This tool make quick work of it. No grindind or damage to chain when it seperates
1 - 2 of 2 Posts
