1 - 10 of 10 Posts
I'm in the market for a rev box, which one's have worked best for you?I've heard procoms can be a pain>
wasteeee of money!!!!!!!! all they do is raise your rev limit and makes your bike more pron to blowing up, buy something else, if your rev box has failed(broken) then the cheapest on is fine... they all do the same
Keep the stock cdi!!! If you want quicker revs you can lighten the flywheel.. But keep the ignition system stock.
How do you lighten the flywheel? Is that safe to do?
Make friends with somebody with a lathe ;) Yes its safe to do if you remove the correct amount of material in the right place..
Firepower or AHP Minis has a flywheel lightening service... Just to name a few advertisers :)
tokyo mods is the best rev box out there raises the rev limiter a bunch , my bike seemed to run smoother with it too.
you can lighten your flywheel , or go with an inner rotor kit too.
1 - 10 of 10 Posts
