1 - 4 of 4 Posts
50CC VFT44 4-SPEED RACING TRANS KIT
Item Code : VFT44
Categories: 50CC 4-SPEED MANUAL TRANSMISSIONS
FEATURED BRANDS!!! : VICIOUS FIFTIES
Model : VF-T44 4-SPEED TANS KIT
Weight : 18.00 LB
Has anyone heard of this kit? How good is it?
wuts the site for it?
Sounds good but after reading and searching...... this is what i found, oh yea does anyone see footpegs ?? :)
http://www.dtmaonline.com/amazing/Itemdesc.asp?CartId={C0BAE1DB-2EVERESTA47-4E53-B8DF-765CCD55542E}&ic=VFT44&eq=&Tp=
Item Code : VFT44
Weight : 18.00 LB
List Price: $999.00
Our Price: $477.00
Vicious Fifties VF-T44 4-Speed Racing Transmission kit for the Honda XR and CRF50!
The ultimate match for your high performance top-end!
Manual Clutch
4 Speed Transmission
Includes all parts needed to install
Assembles into stock Honda engine, no case mods needed!
Fits: All Honda Z-50, XR-50 and CRF-50 engines.
The VF-T44 4-Speed Racing Transmission kit features a 4 speed gearbox with a big-bike shift pattern (down for low, then up for 2nd,3rd, 4th). Fourth gear is like an overdrive, you'll run away from any three speed 50, no matter how much they've been modified. The Manual Clutch gives you instant Holeshots, plus you can fan the clutch lever to gain revs quickly in the corners.
Ready to install. Kit includes:
Transmission main and sub shafts, assembled with all gears, spacers and circlips, and countershaft sprocket.
Manual clutch assembly with drive and driven gears, all clutch plates, springs and lifter assembly, kick starter shaft and new clutch cover.
4 Speed shift drum with shaft, forks and all clips.
All bottom end gaskets, clutch cable and shift lever
Installation requires top end gaskets for your size piston and one special tool (clutch nut spanner, Motion Pro #08-0015, avail separately). Clutch lever and perch not included in kit, use CR80 style. Typical installation time for a skilled mechanic is under 3 hours. Due to the larger clutch cover, we recommend an aftermarket step bar (footpeg mount). Some spacers may be required if using the stock step bar.
1 - 4 of 4 Posts
