1 - 11 of 11 Posts
Where does the V clip go? Need help. Put jets in and gas flowed through air filter. We have the needle and v shaped clip out right now and need to know how to put back together. Help would be great. HURRY
Thanks
Discussion Starter · #3 ·
wait not sure on what you mean. there is also a housing that i guess the needle and clip go into...? how would it go in?
At the bottom of your slide there is a hole that the needle goes in. The clip goes on top of the needle inside of the slide.
if its V with curls on the end it goes on top of the needle jet. It keeps the needle in place. so put the needle in .. the V clip on top of the needle .. then put the spring on and screw the cap on the carb
U tube it, some where on there you'll find the Needle clip. First time I took a carb apart it flew aross the garage!
1 - 11 of 11 Posts
