81 - 100 of 128 Posts
There are some things you cant put a price on, Stormins work is one of those things. Hope you keep progressing with it.
Discussion Starter #86
Wham bam! And it's getting packed up. StorminNorman did the work for a great price. Can't thank the guy enough. Well now it's all in my hands hopefully be running by the end of May.
Discussion Starter #87
Wham bam!! Almost all asssembled. Have to install the clutch and waiting on a new intake valve as I bent one when I installed the new retainers awhile back. Also I'm going to have to do some MAJOR massage work to make the CRF carb fit.
Big thanks to StorminNorman all of the machine work turned out beautiful even made to bad cranks I sent become one good one.
<img src="http://planetminis.com/forums/attachment.php?attachmentid=173754"/>
<img src="http://planetminis.com/forums/attachment.php?attachmentid=173755"/>
I'm liking it! Have you mocked up the external oil line yet?
Yeah banjos fit great I just need to order the hose and the cooler. I'm not sure the 150 carb is going to fit without some crazy work on the tank/frame unfortunately
Awesome. I was a little worried that you may of had to relieve a little bit due to having to sink deeper than I wanted to get a nice spot face for sealing.
" I'm not sure the 150 carb is going to fit"... when all else fails pull out Thor and beat it til it fits lol
Discussion Starter #91
Well the 150r carb is a no go. It's too tall and too wide to fit in the frame and have even a half way decent airflow path. So it's been tentatively sold (as long as I receive payment) and I've started ordering up the next set up. I am usually a guy who goes with the simplicity rule but I am already way passed that.
Future fueling/ignition plan.
Microsquirt EFI/Ignition
Coil on plug
34mm throttle body
160-180cc injector
Yamaha YBR 125 Flywheel
External fuel pump/regulator
And a whole ton of luck. In the mean time while all of that is on order. im fixing up a few things on my cb750 to kill time. The new intake valve should be here in a week or so. And I'll finish up the bottom end.
Discussion Starter #94
Well still waiting on quite a few key parts but I've started mocking up and building my wiring diagram. Don't want to splice the harness until I know 100% I'm happy with placement. But here's a quick cardboard mock up. Also oil Cooler mocked up.
I'm more of a HOLY CRAP!!!! kind of guy!!! I can't wait to see this thing go!!!! You've got some serious confidence to go that route on the EFI!! Although I totally understand your reasoning. I wouldn't know where to start, what maps to use ..etc!!!! Good job!!! I'm seriously inspired!! WAY TO GO!!!!
-Robbrt
Discussion Starter #97
Well wiring should be sorted as far as where to connect what once I'm ready. Got the electronics box half way done. Think I've sorted out where I want to put everything. Made the new ports in the fuel tank had to get a little red neck on it but it doesn't leak fuel currently.
Used 1/8" aluminum used the oem petcock mounts. Tapped the aluminum for 1/4" fitting which convert to 6an. Then for the return port drilled tapped and helicoiled the tank for 6mm bolts. Then also drilled and tapped the aluminum for 1/4" npt. Then covered the whole backside of both plates with yamabond which is fuel safe. If all else fails I have a few back up plans. Have some base maps set up which should get me all up and running.
Discussion Starter #98
Well some mild updates. The electronics box is almost ready to be replicated in carbon fiber. Still need to figure out a few mounting points and finish up the rough wiring. Then it will be off for some fabrication work for the intake manifold and getting some brackets welded. Need to order my iac motor controller for the microsquirt. Might be slow going due to money constraints right now with some medical bills. But should at least have the wiring done soon.
I just bought a ttr125 this week and I have been spending countless hours researching engine upgrades. This is like the Holy grail. I hope you get it running soon, I can't wait to see a vide!
