1 - 2 of 2 Posts
Ttr125l, xr70, ct70, ct90, ct110, xl100, xl125, tw200, cb350t
I have a highly modded 2003 ttr125l and I was wondering if there was a better frame for it. If not are there other forks (besides the yz) that will fit?
The only frames that were made specifically for the ttr125 was the BBR perimeter frames but they used cr80/85 suspension and body work and they are very scarce. Forks there are alot of people who have done conversions from kx85/100(same forks as yz85 minus the rebound adjustments). Pair that with a frame cradle and its a decent setup without alot of work as the front end swap is not bad at all. For a good rear shock to match the the ttr125le can be revalved to work well
1 - 2 of 2 Posts
