i just picked up a 2000 xr50, and although it's in rough shape it's ridable. so far i've found, it's hard as hell to start after being cold, almost to the point where it won't start, but once it's started and warm i've got it idling smooth and running just fine. it needs to be rebuilt for sure, cause it's severly lacking on power, but my main concern is the tranny. while in nuetral it's really hard to get into 1st, but it'll go if you raise the shift lever hard and far enough. but occassionally when trying to shift to any gear the bike will just fall out of gear all together. it doesn't do it while riding, but if you stop or try to shift sometimes it happens.
before i go putting any money into this bike at all i want to get the tranny and motor fixed and running just as good as my 03 xr does. i'm lost as to where to start in order to get this bike up to par. any ideas, tests, things to look for, anything at all that would help me figure out what's causing my tranny problem or how to fix it would be grrreat.
i've rebuilt 2-stroke motors before but haven't messed with these itty bitty 50 motors. besides a manual, is there any where i can get some information about the rebuild process and/or adjustments?
thanks again.
thanks again.
