1 - 20 of 22 Posts
what special tools would you need to work on a crf50 engine?
i know about the clutch nut tool but are there others?
if so, what are they?
and does anybody have any extra's that they would sell (or give) for cheap?
thanks
Torque wrench is number one on my list when doing anything with a motor!
clutch nut tool is a must
ive never had to use a flywheel puller on any 50 motor ive worked on or a clutch holder!
my favorite tool in my tool box is a snap-on ratchet screwdriver that has a kinda T handle that thing will undo any screw thats not rusted solid :D
impact tools are also very helpful;)
· Banned
You should have a feeler gauge for setting valve lash, and the adjuster tool if you can swing it. Impact driver for stator plate screws, or a left-hand drill bit and replacements with an Allen hole for later removal. Snap-ring pliers. Razor blades and a sharpening stone, to remove gasket leftovers. And, the phone number of a trusted machine shop for piston to bore clearance checking and head work. Those are a little more specialized than the average garage would need.
twosmoke30 said:
how much for flywheel puller $16.00
clutch nut tool $19.00
and clutch holder Hang on tight;)
Ok see this post, this is someone who is really trying to help, not just someone trying make a damn $$ off ppl.
Proud to know you Terry, you sexy bish!
1 - 20 of 22 Posts
