Tire pressure question
1019 Views 9 Replies 9 Participants Last post by  Scott982
Skinny guys need not apply!!! jk
Im kind of a heavy guy, well 255 lbs. And im starting im kinda wondering what pressures bigger guys run. There is about 27 lbs of air in the tire now which is good because it doesnt squat anymore. But I feel like I am losing some advantage when im doing circles to the decreased surface area. If anybody has had experience with something similar that would be great.
thanks, Matt
1 - 10 of 10 Posts
thanks, Matt
I'm 6'3" 240#'s and i run 20 in both tires of my X4....any lower and it would pinch a front tube sometimes
Well since your bigger I would keep more air in, obviously. Just sit on it and look down lol you can tell if its to flat or to full, I dont know aout PSI though. the flatter the better for wheelies, BUT to flat is obviously not good and can bend your rim and pop your tube
I don't even use a pressure gauge, just pump it up then squeeze the tire hard to see if its good then sit on the bike and look at the tire maybe bounce alittle on the suspension.
I'm with you
I prefer a lot of pressure for circle wheelies but I have no idea what PSI I run.
i used to run 15psi, but flat tires were a problem. i now run 20psi front and rear and its holding up fine. i weight 155lbs...so u might need some more. make sure u have a rim lock.
Yeah, I think there is room to make the back tire flatten out a little more. Going to have to wait for spring though.
I run pretty high pressure (I don't use a gauge cause my gauge wont fit the 50 wheel lol)
But when I first learned I ran really low pressure, but as I got better I realized low pressure held me back..
It's nice cause low pressure makes it easier to keep it up and balanced, but once you start doing fast circles and stuff, the low pressure makes the bike ride unpredictably
edit: same with my sport bike, started running 15-18psi, now I always run 28-32
I run around 25psi or so on the 50 and 28psi on the f4i.
1 - 10 of 10 Posts
