1 - 5 of 5 Posts
Well I tried to do a search but I did not find anything pertaining to my issue. I have a CRF50 with a 50 Stunt tall bar kit. And I am running a 125cc with a 22mm Mikuni carb.
The issue I ran into was the cable doesn't work with the Mikuni carb, Because the exposed wire isn't long enough to go into the slide. (I think that is the right term.) But I am having issues finding one that will fit the carb right and also be long enough for the tall bars. The one I got from a friend works with the carb but isn't long enough for the tall bars.
I was wondering if anyone had a link to someone that has what I need or maybe any ideas of what I could try.
Thanks for your help.
your local dirtbike shop should be able to make you a cable, using the outer cable from the 50 stunt kit.
i had my buddy at the shop make me a clutch cable because i wanted to ride while waiting for my motion pro
EDIT: you're in so-dak so what i said above will be difficult, unless a dealer will do it.
i used to live in watertown.
Discussion Starter · #4 ·
Our shop here isn't the greatest and if they find out it has a "china" engine they will refuse service to you. Right now I am emailing Vince from Tbolt to see which cable they have that he thinks will work best for me.
what throttle u have dude.I hadto buy a aftermarket throttle that t bolt has for 20 bucks and its the hrc one and it damn woth the 20 for sure then i have the braided cable from wholesale-cycle i thinks its the 160-r cable and its plenty lons.I had the same problem with my bbr throttle that was basically a stock setup the cable that came with my 140 wouldnt work so i bought the hrc throttle which is basically the billet pitster pro throttle except the hrcone has a plastic throttle tube but cost 40 less too lol.
1 - 5 of 5 Posts
