41 - 49 of 49 Posts
· Vendor
Discussion Starter · #41 · (Edited)
[h=1]DNM KLX110 Rear Shock (250)
Part No: WHS-1401
[/h]
SHOCK DNM MK-AR for KLX110
DNM Pit Bike shock with adjustable rebound.
Designed for the Kawasaki KLX110.
Uses a 250 lb/inch coil for LIGHTER adult riders.
(Bigger Guys need a 350 spring)
270mm eye to eye
10.65" eye to eye
· Vendor
Discussion Starter · #43 ·
[h=1]TB CRF110 20mm Carb Kit
[TBW9142][/h]
Date Added: Saturday 25 January, 2014[h=2]by Ethan H.[/h]
The carb makes a huge difference to the power, its almost like a completely different bike. For a 120 bucks, its a great deal. I was a little skeptical of running the filter with no airbox at first but it doesn't get that trashed and no dirts gotten into my carb at all
· Vendor
Discussion Starter · #44 ·
UPDATE:
We are now offering a CR type throttle in all the CRF110 kits that include a carb because the cable provide wont work with the stock throttle
Actually the stock throttle doesn't have enough throw
Part No: TBW9142[/h]
Complete Carb Kit that includes the reverse intake, 20mm Carb, airfilter, main jet kit, and a throttle cable
NOT for use with stock air box
NOT for use with stock throttle
UPDATE: We are now offering a CR type throttle in all the CRF110 kits that include a carb because the cable provide wont work with the stock throttle Actually the stock throttle doesn't have enough throw [h=1]TB CRF110 20mm Carb Kit Part No: TBW9142[/h] http://tboltusa.com/store/images/9142.JPG Complete Carb Kit that includes the reverse intake, 20mm Carb, airfilter, main jet kit, and a throttle cable NOT for use with stock air box NOT for use with stock throttle
Aw man I just ordered the vm26 reverse kit!
R.R.N.S. - Rail Ruts Not S!u+s
· Vendor
Discussion Starter · #47 ·
Back in stock
[h=1]BBR Damping Rods - CRF110F
Part No: 634-HCF-1101
[/h]
These front fork damping rods replace the stock damping rods to increase travel and provide increased damping control for adult sized riders.
Slows rebound and increases compression damping for a firmer more controlled ride.
These make a great combination with our stiff springs.
A perfect match to our SuperStock swingarm.
• Increases travel 1.5" from stock
• Better damping control with stiffer springs and adult sized riders
• CNC machined from solid steel rods.
For CRF110F, 13-Present
· Vendor
Discussion Starter · #48 ·
here a pic of our stock mod CRF110 we build
Stock Swingarm (We have the BBR Super Stock Swingarms here for sale and that would have been cool too ,but opted to keep the budget that much lower)
134cc kit with Big valve Kit (ported by Norman)
VM26 carb kit
BBR Skid Plate
DNM Shock
TRC Inverted fork kit with disc brake
Kinetic MX HD Pegmount with Stainless peg kit
FMF Factory 4.1
TBparts Aluminum shifter
Tboltusa exclusive Pro Taper Tall bar kit
https://tboltusa.com/store/pro-taper-handlebar-kit-tall-bars-wcontrols-crf110f-p-10644.html
Land vehicle Vehicle Motorcycle Car Automotive tire
· Vendor
Discussion Starter · #49 ·
After a few requests for taller bars we now offer
PRO TAPER HANDLEBAR KIT - TALL BARS W/CONTROLS CRF110F
Part No TRC-10948
This kit includes Taller than stock
Pro Taper XR50 SE aluminum bars w/bar pad R-025262 rise 152mm (5.9 in.)
We also still offer
PRO TAPER HANDLEBAR KIT - BARS W/CONTROLS CRF110F Part No TRC-10644
This Kit includes similar to stock rise
Pro Taper SE aluminum bars w/bar pad R-025302 Rise: 123mm (4.8 in.)
Text Font Line Screenshot Parallel
41 - 49 of 49 Posts
