1 - 3 of 3 Posts
My buddy just got his TB manual clutch installed and now his White Bros pipe doesn't fit.
It hits the cable mount.:evil:
Anyone know a fix for this?? :(
He just bought the pipe about a month ago, he's gonna be bent if has to get another one.....
How badly does it hit the cable. Is the clutch still able to operate, if the actuator arm still works, you may be able to come up with something to pull the cable away from the pipe or at least protect it from the heat.
Discussion Starter · #3 ·
The cable doesn't hit the pipe. It's the actual cable mount on the side cover. The pipe won't even bolt up. Looks like the pipe has to be bent to make it fit. WB makes their pipe fit so tight to the motor...... :evil:
If you're looking to get a manual clutch, don't buy a White Bros pipe....unless you have a bender.... :?
1 - 3 of 3 Posts
