Ive scanned the internet looking for somone with the same problem and cant find anything. My clutch was making some werid noises so i took the clutch cover off and tightend the clutch nut(that was the problem) and in the process lost that little spring that goes in the middle of the bearing. I used another spring i had that fit and put everything nack togather and now my clutch stays engaged. I tried to adjust that plate behind the chrome cover and ive also tried to adjust the clutch wire. Im wondering if its that spring and if so do i even need it for the clutch to work properly? What does it do?
