1 - 13 of 13 Posts
Premium Member
Have some S25 D-Comp cams for the Takegawa KLX +R head and the TB V2 roller rocker head. Makes kicking your bike to life effortless, no more damaged cases and kick start shafts!
Price - $225
Link to product on AHP store - Ahp Minis
Also have the Takegawa 1 down 3 up shift drums in stock finally!
Takegawa 4-Speed Shift drum with a 1 down and 3 up shift pattern. This kit will match the shifting pattern of your big bike and moves the neutral position of the transmission between 1st and 2nd gear, ensures no false neutral shifts when a quick down shift to 1st gear is needed.
Price - $99.95
One last thing back in stock is the Kitaco kickstarters, these are super nice and give you more leverage. Nice heavy construction and the highest quality Japanese plating and design.
Price - $62.00
Contact - [email protected] or 610-417-2533
payment - credit card or paypal
::AHP minis:: | iShock, Honda Trail Bikes, Fast50s, Boyesen, and Sano
Premium Member
Discussion Starter · #4 ·
A!dam said:
Can i fit the Takegawa D-comp camshaft into Chinese YX 160 engine?
Does it improve performance?
What head are you running, these are for the Takegawa +R or the Trail Bikes V2 roller rocker heads. Depending on the grind you get, it will affect performance, these S25 are the good all around grind that would most match the V2 cam.
Premium Member
Discussion Starter · #6 ·
JJC2374 said:
Is the 20 or the 25 better for me. I have a 138+r with a 26mm carb
It depends on what type of power your looking for, S25 is good for moto guys and Supermoto guys love the S35 for the street/road racing applications:
Iam running Stock head, but ported, cut off valve seals.
Iam looking for D-comp camshaft-if i can fit it into my motor and if i improove performace.
P.S: The picture from dyno-what engine is that?
Thanks
Premium Member
Discussion Starter · #8 ·
Thanks
These cams will only fit the rocker heads, I believe its a cam chart for the 178cc Takegawa Scut on the KLX110 engine.
Banned
NOPE, THAT DYNO IS FROM A 138+R HENCE WHY THE S35 CAM DOES NOT MAKE A BIG CHANGE IN HP. HERE IS A TAKEGAWA DYNO OF A 178+r. YOUR WELCOME MARK.
Premium Member
Discussion Starter · #11 ·
Thanks for the clarification, I guess what i believed off the top of my head was not correct. Makes sense now that I think about it as thats probably the original illustration from a few years ago before the 178cc scut came out.
Iam sorry, but rocker head is which for example?
So its not possible to use it with my head?
Thank you
Premium Member
Discussion Starter · #13 ·
Thank you
As mentioned this would be the Trail Bikes V2 roller rocker head or Takegawa +R head.
You can see them here:
V2 Head - Ahp Minis
Tak +R Head - Ahp Minis
1 - 13 of 13 Posts
