1 - 8 of 8 Posts
hydroman-420 said:
will it bolt up to the stock frame with no mod?
what needs to be done for the brakes to work?
may need a shim (washer) or two for the swingarm pivot bolt
and have to either weld a tab for the brake panel or use a bolt
there is a post on here how to do it....it is the least expensive route to get a +2 swinger
hydroman-420 said:
I got an xr50 does anyone know if thet make a +2 swingarm that I can use the stock rim,hub and brake drum?
thank you
check the for sale section.
Pretty much all of the +2 swingarms that are made for a XR/CRF 50 will work. Other than probably needing a brake rode extender or a XR70 brake rod.
1 - 8 of 8 Posts
