1 - 8 of 8 Posts
I have a klx with KX 60 front suspension and a BBR Super pro swinger with the Elka.
My questions start with if I throw a set of zokes on the bike how will the bike sit with the super pro swinger? If it will be un-level then what options are there and which ones would you recommend.
I already have the forks, just need a triple's...heres the second question.
With the KTM 65 triple clamp all I need is a tampered bearing kit and they should bolt up...correct?
Thanks for the help.
Depends...Which Marzocchi forks do you have:
KTM Marzocchi's with KTM 65SX lugs?
Marzocchi's with Kawi KX65 lugs? or
Marzocchi's with Marzocchi lugs?
Discussion Starter · #3 ·
The Zokes I have came on a Polini XP65...I have not bought the triple yet. I guess I could look and see if the polini triple clamp might work.
Polini uses a AJP front brake.
How can I tell which ones I have?
I don't know if the Polini triples would work. Maybe? Might have to get adapter spacers made for it; as long as the steering stem is tall enough. (or press in a KLX or KTM stem?)
I just measured up some KTM triples for you:
166mm Forks center to center
bottom triple fork clamp: 48mm
top triple fork clamp: 45mm
steering stem diameter: 20mm
205mm measured from the bottom of the lower bearing to the top of the steering stem/nut
See if these measurements line up with your Polini front end.
Discussion Starter · #7 ·
I didn't measure the Polini triples, i just bought a set of KTM 65 triples....
Will I be able to get the bike to level out ok with the Zoke legs and the rear BBR Super pro swinger w/elka shock?
Yeah, it should sit okay.
My Marzocchi's are 734.5mm from the center of the axle to the lip of the top cap.
1 - 8 of 8 Posts
