well ive done some searching and cant seem to fine anybody will the exact same problems im having...
its an 04 klx that i just got, my first 110
im assuming the nut with the screw on the inside on the clutch cover is the way to adjust the clutch?
1st, the kick starter will not always engage... every 10 kicks or so when its cold, and once its warm it rarely happens, ive adjusted the clutch and still nothing, is it the centrifugal clutch? ive talked to a few guys that said that what it could be. if it is, is it hard to rebuild it?
2nd. after installing a new sunline shifter the bike is impossible to shift under power and tough to do when at an idle, ive adjusted to clutch and it helped a little but its still jacked...
it wasnt quite as bad with the stock shifter, and the new one is not rubbing or hitting anywhere.
