shift fork help
500 Views 1 Reply 1 Participant Last post by  Scotch
how do I know if my shift fork is bent...
1. What is it?
2. Where is it?
3. How do I know if it's bent.
My shifter was slipping out of gear when I would try and take off. What I found was that the little pin on top of the shift drum came out in the oil before I even split the cases.
Would that cause my problem?... I would think it would, personally. The the shift drum wouldn't be seated correctly right?
i am also installing the Kawasaki drum, and it has two holes for the pin. Do I need another one?
Thanks!
Status
Not open for further replies.
1 - 2 of 2 Posts
1 - 2 of 2 Posts
Status
