1 - 4 of 4 Posts
I have an SDG pro mini frame that i"m building a new bike with and when i went to put a cheap pair of forks on that i had the steering stem wasn't long enough does anyone know if i bought a set of fastace as-02's would they bolt on?
you have to get a set of tripples that have a 220mm stem....the SDG uses a longer stem than the Honda styled frames....you can sometimes find the stems on fleabay....wholesale cycle sells new tripples with the longer stem...I think I have a used lower tripple for an SDG......measure the diameter of your upper fork tubes and when I get off work I will see if the one I got will work for you....most fast ace come with a 200mm (Honda Style) unless you ask for the china style
1 - 4 of 4 Posts
