are the hubs the same? i know the spoke are differant but not sure if the holes are?
LongMooie · Registered Joined Jun 16, 2005 · 4,284 Posts Discussion Starter · #1 · Jan 10, 2009 Only show this user are the hubs the same? i know the spoke are differant but not sure if the holes are?
LongMooie · Registered Joined Jun 16, 2005 · 4,284 Posts Discussion Starter · #2 · Jan 12, 2009 Only show this user no one knows? come on i know some of you run those huge 12" rims!!! are there more holes in the 12" rims or the same as the 10s
doopsx3 · Registered Joined Aug 22, 2008 · 7,611 Posts #3 · Jan 12, 2009 Only show this user you can get 12's with whatever spoke count you want...I have some 12's with 28 spoke holes
LongMooie · Registered Joined Jun 16, 2005 · 4,284 Posts Discussion Starter · #4 · Jan 12, 2009 Only show this user doopsx3 said: you can get 12's with whatever spoke count you want...I have some 12's with 28 spoke holes Click to expand... Ah i see i dont want 12s i was looking at a wheel that had a 12"rim on a billet hub and just wondered if i could just change the rim to a 10"
T travisellis02 · Registered Joined Jul 18, 2008 · 42 Posts #5 · Jan 12, 2009 Only show this user ebay has 12" wheel kits.. for the drum brake style. i have ran some of these, and havent bend one yet. what i did is just change out the cheap tire they have on them I have also laced a 10" stock wheel to a 12" rim. i had to bore the holes alittle
doopsx3 · Registered Joined Aug 22, 2008 · 7,611 Posts #6 · Jan 12, 2009 Only show this user yeah it should work as long as it is 28 spoke
monaghan · Registered Joined Dec 13, 2008 · 1,487 Posts #7 · Jan 12, 2009 Only show this user its the same.
LongMooie · Registered Joined Jun 16, 2005 · 4,284 Posts Discussion Starter · #8 · Jan 12, 2009 Only show this user cool thanks guys ill check to see if its a 28 hole hub so i can run a 10
