1 - 4 of 4 Posts
the diagram for sl70 shows the shim on low gear shaft end missing, z50 diagrams shows it.
first is sl70, item #1 has no shim.
second is z50 item #1 shows a shim.
i just sealed up my bottom end with z50 cases, sl70 internals including 4 speed gears, and 70's crank.
Your information is good. The Z50's...3speeds use 2 shims (thrust washers) Most 4speeds only use 1.
1 - 4 of 4 Posts
