1 - 5 of 5 Posts
When I am off the gas just before a corner, the bike still wants to go forward, as if i am on the gas a bit, sort of surges forward any ideas??? - new cable, not hooking anywhere - I suspect the jetting.
Try (with warm engine) blip the throttle in neutral and see what happens... does it idle high and in then in a minute goes to normal idle? If it so than your air screw is to much out (lean). Try to turn it clockwise for 1/4 of a turn...then try again...if you out of adjustment then you'll have to go with bigger jet
1 - 5 of 5 Posts
