1 - 2 of 2 Posts
hey im in the process of splitting the cases but when i put them back to geather the oil gear and its shaft keep getting jammed and do not spin freely?
anyhelp???
thanks
Chris
Banned
Sounds like it's not fitting in the pump correctly, or you bent it on dis-assembly.
Look at the pump cover plate and make sure you haven't warped it from squeezing the cases together with the shaft out of it's slot. You'd have LOW oil pressure if you did.
1 - 2 of 2 Posts
