i bought a set of brp triple clamps to install 65 forks on a 110, my problem is that when i tightened the lower bolts the fork tube turns, but the top tightens good i have installed many fork clamps but never had this problem but never this wide with three bolts. the bolts are torqued to 18 pounds ft-lb, im afraid the bolts will strip if i go any tighter because they are only 8mm bolts, the torque for the stock bolt was 22 pounds but a 10mm bolt, has anybody had this problem
